メインコンテンツにスキップ
THINKPAD T520。トップレベルのパフォーマンスとポータビリティ。
締切られた回答
Why does my laptop keep on beeping at me?
A few months after i got my laptop something weird was starting. Everytime I kept on trying to turn on my laptop it kept on beeping three times at me. It also stops the screen from turning on, can someone please help me, I need to fix it!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Katie Louise, you should tell us more about the exact beeps.One long and two short beeps, and a blank or unreadable LCD are indicative of either a bad mother board, a bad LCD, or bad memory modules. I would start by attaching an external monitor and see if it makes a difference. After that, pull the memory modules and reinsert one module at a time. Make sure that it is properly seated. If none of this works, you probably have a bad mother board. Hoe this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
The first beep is long, and then nothing happens for 2seconds than the other two go one after the other. I have a bad mother board, i tried all your steps but none of them worked :( thanks for trying to help anyway :)
さんによる
Thank you for accepting my answer. sorry to hear about your motherboard. May be you could still be covered under warranty?
さんによる
コメントを追加
この回答は他の質問に帰属しています。
3 BEEPS -- PAUSE 3 BEEPS ETC... USUALLY EQUALS MEMORY UNSEATED OR MISSING. Reseat the memory in it's sockets
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My computer is beeping. There is usually 4 quick beats, then over 10 slow beats, then just random. What could the problem be?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
sonya what make and model is your computer?
さんによる
Hi, it is an Acer aspire 5732Z
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 5,379
