メインコンテンツにスキップ
THINKPAD T520。トップレベルのパフォーマンスとポータビリティ。
17回答 すべてを表示
Why does my laptop keep beeping at me?
Okay, I have had my laptop for only a few months and something bad has already happened! Everytime I try to turn on my laptop it gives me 3 beeps over and over again, also my screen isnt turning on whilst it is beeping! Someone please help, I need my laptop back
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
Katie Louise, you should tell us more about the exact beeps.One long and two short beeps, and a blank or unreadable LCD are indicative of either a bad mother board, a bad LCD, or bad memory modules. I would start by attaching an external monitor and see if it makes a difference. After that, pull the memory modules and reinsert one module at a time. Make sure that it is properly seated. If none of this works, you probably have a bad mother board. Hoe this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
The first beep is long, and then nothing happens for 2seconds than the other two go one after the other. I have a bad mother board, i tried all your steps but none of them worked :( thanks for trying to help anyway :)
さんによる
Thank you for accepting my answer. sorry to hear about your motherboard. May be you could still be covered under warranty?
さんによる
コメントを追加
3 BEEPS -- PAUSE 3 BEEPS ETC... USUALLY EQUALS MEMORY UNSEATED OR MISSING. Reseat the memory in it's sockets
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
この回答は他の質問に帰属しています。
My computer is beeping. There is usually 4 quick beats, then over 10 slow beats, then just random. What could the problem be?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
sonya what make and model is your computer?
さんによる
Hi, it is an Acer aspire 5732Z
さんによる
コメントを追加
回答を追加する
Katie Louise さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 1,118
