メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
Why my s3 not reading the sim
hi, my s3 is not reading the sim card, the problem is on the board becoz i tested with other sim slot flexi cables, can anyone send me a pic of any sim card control chips on the board. thanx in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
my phone have that problem but it does not recieve and send anything its detect as no sim card
さんによる
my phone have this problem this by sim card was detected but when i restarted that phone they are[Emergency Calls Only]
さんによる
コメントを追加
4件の回答
最も参考になった回答
Try cleaning the connections of the SIM slot with a folded piece of paper dipped in etanol or put a couple layers of sticky tape on the back of the SIM to see if slightly more pressure on the contacts will help. You may need to replace the SIM slot assembly
The SIM slot assembly is available - HERE is one example and there are listings on eBay also.
THIS VIDEO may also assist you
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
i have 2 s3 boards that means 2 sim slot asemblies, i m looking for some hardware tecnition who has done the job before... me myself i m a cell phone technition plz anyone with a solid idea or solution????
さんによる
The sim slot assembly I linked above is a plug in part. Are you are wanting to swap only the SIM contact from the assembly?
さんによる
Thanks for this it was very helpful
さんによる
コメントを追加
Salut eu am un samsung s3 si imi da cartela sim afara de ce eu o inpinge si ea no inpinge afara de ce ce are ea acola inautru arcsoru ala e de via nustiu de ce are
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Why my s3 didnt read the contact numbers from my sim?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
When you put the sim in the S3 you might have to sometimes import the Contacts from the Sim. Please follow the steps to import the contacts from your SIM.
Go to Apps through Home screen.
Scroll to Contacts, then tap on it.
Tap on the Contact tab.
Tap on Menu key.
On the pop up menu select Import/Export.
Tap on Import from SIM card.
Tap on Phone.
Tap on Select all.
Tap on Done button.
Finish. Now all contact on your SIM has been successfully copied to your Phone.
http://www.Dashrepairs.com
さんによる
コメントを追加
i have the same problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Muhammad さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 24,744
