メインコンテンツにスキップ
The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
Battery or charging port
Hi, How can I check whether there is a problem with my motorola xoom tablet battery or that battery is fine but fault with charging port?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
7 件のコメント
What is it doing? Does it respond when plugged in? If so then is it just dieing quickly?
さんによる
It is just dead all of sudden, does not respond at all. Even when I plug it in, there it no lights (white or red) to indicate that it is connected or charging. But when last time I used it, the battery was at may be 15% and the battery life didn't seem to be a problem as it did not run down very quickly, just it was normal duration. So now that it is not responding, does that mean that it has ran out of charge and the battery is not charging either due faulty battery or faulty charging port? Thanks Austin
さんによる
my tablet is not charging from a day what do ido buy a new charging port or a new charger?????
さんによる
and no lights to indicate that it is charging
さんによる
Ordered the charging platform unit with power n charges now.plug still not working waiting for car charger now. Wonder if something broke off inside
さんによる
2件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
Not the battery, not the charger... its the charging port! Apparently there is a slight difference in the diameter of that cheezy, tiny tip. The port hole is too large for most charging tips, doesn't matter if you get the charger from Moto or 3rd party. I have tried five; found one that works, but it is a 12v DC charger... so I plug in at night in my truck and its charged the next day. Pain; but Moto wont acknowledge the problem - check any forum... but Moto will look at for $150!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Can you share a link to the charger that you purchased that worked?
さんによる
Where can I find that charger? I have the same problem with my tablet.
さんによる
コメントを追加
最も参考になった回答
It's the charging port on your Xoom. Order the replacement for $7 and with a T5 tool you can replace it yourself in 15 minutes. Check out YouTube video on how to do it. Or, I just removed the charging port and use the docking station. You need to remove the charging port in order to use docking station
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
where can you get the replacement and the tool?
さんによる
Any tool depot place like Home Depot , lowes or any hardware store. I picked my up from Home Depot.
さんによる
And a docking station will solve ?
さんによる
If the port is not good,you'll need to remove it to use the docking station. Bad port shorts out the port and will not allow docking station to work. Buy the port it's cheap and replace use the docking station, it's more reliable than the cheap charger plug
さんによる
How to use the docking station...
さんによる
コメントを追加
Hi..sounds like it went dead. Charging might take longer than normal. Take a look at this information: http://www.xoomcommunity.com/forum/xoom-...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 17,978
