メインコンテンツにスキップ
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125回答 すべてを表示
Where can I get LCD panel for Galaxy Tab 2 7.0?
My GT 2 7.0 digitizer was broken, so I replaced it using heating gun. But after the replacement my lcd panel does not show any pictures. (I still can listen sounds when I touch the screen so new digitizer works). I guess I broke the lcd panel when I was replacing the digitizer. The problem is I cannot find where to buy LCD panel for GT 2 7.0. There are so many posts about GT 2 10.1 but 7.0 and I only can find new digitizers, not LCD panel itself for GT 2 7.0.
Can anybody send me the link? (Amazon is preferable)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Found one on eBay UK: http://www.ebay.co.uk/itm/Replacement-Sa...
I imagine they'll be one on USA eBay if you're from USA.
Before you go ordering parts though, does the LCD display anything at all? You could have forgotten to clip the LCD Ribbon back in or incorrectly clipped it into place, both would require opening the Tablet back up but if it saves money then it's worth a shot. When using the heat gun did you take care not to leave it on the same spot for over 5 seconds? Also what temperature setting were you operating it on?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you so much!
I can see backlight and blurred images on LCD panel. So I guess it is not about connection problem. There is not really cracks on the panel. Maybe I overheated the LCD panel when I was using my heat gun(actually I used hair dryer). Do u think I can fixed the LCD panel without any extra cost?
さんによる
コメントを追加
回答を追加する
Brooklyn Tiger さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 2,644
