メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
Phone shows plug into iTunes
Screen shows that I have to plug my phone onto iTunes and it will not do anything els please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント
What happens when you plug it in? Did anything happen to phone? did this just start? Give us some more info.
さんによる
I reset the phone and this has just come up
さんによる
How did you reset this phone?
さんによる
コメントを追加
3件の回答
最も参考になった回答
Hello, (Please read full answer before attempting).
Please try plugging the iPod into your Computer and loading up iTunes, A window should then pop up saying that your iPhone is in recovery mode or just that it needs to be restored before you can use it. Proceed to restore the iPhone.
It can take a while so do not be tempted into resetting it during the Restore as this causes the Connect to iTunes page to appear again and is sometimes irreversible with iPhones when the restore is interrupted.
If the restore works then your phone should be back up and running, if not then load up iTunes again and it will say restore unsuccessful and will give you an error code. If the restore did not work please comment the error code and we will go from there :)
Sadly I do not think you can back up the data before hand and the iPhone is failing to start so needs the software reinstalling or hardware replacing.
Please comment your results :)
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Hi there my iphone 3g has been out of action for a while as its been saying connect to itunes for nearly two years everytime I try recover my phone it doesnt work please help !!
さんによる
Eror code: 1015
さんによる
コメントを追加
In this situation, it indeed indicates that you have been stuck on recovery mode screen. The intuitive description is iPhone display with USB icon and iTunes logo, you can easily and quickly fix this with a free and excellent program named ReiBoot provided by Tenorshare. Have a try.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
are you able to do it for me ?
さんによる
um the software you mentioned (reiboot) is not free, in order to do anything with it it ass you to register and pay a minimum of 35 dollars!!!!!!! :(
さんによる
コメントを追加
I hv the same problem with my iphone 3g
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Craig Joyce さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 7,832
