"Contol locked" light is on.
Help! I already tried to the steps above but still doesn't work =/ the light is still on it does not turn off =/
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try pushing the '"Auto Dry Level"' button for 3 seconds and the '"Cycle Signal"' button for 3 seconds.
If this doesn't unlock the control panel then it is likely your interface control board is faulty.
このアンサーは役に立ちましたか?
THANKS! !! !!! RICHDAVE! My wife was out of control! !! !! Auto Dry Level button and Cycle Signal button for 3 seconds FIX IT THANKS RICHDAVE!!!!!!!!!!!!!! P.S. I O U A BEER!!!!!!!!!
this works thank you
Worked for me too. Thank you!
Much thanks seriously badass!
WOW! Just WOW! It worked! Thak you.
過去 24時間: 1
過去 7 日: 21
過去 30 日: 65
今までの合計 8,988
1件のコメント
Okay, so you tried the steps from here "Contol locked" light is on. Nothing else responds.. what else have you tired and how long is this going on? did anything happen prior to the control lock light coming on?
oldturkey03 さんによる
