glass replacement of iPad mini-reg
my iPad mini glass broke down due to a fall.in india the store ask 17000rupees where as mini costs 21000only.
kindly guide
rao
この質問は役に立ちましたか?
kindly guide
rao
この質問は役に立ちましたか?
The issues with the repair is there is an intensive solder job that must be done to remove a part of the digitizer connection flex and add it to the new digitizer screen. Its very possible and easy if you know how to use a typical solder station and hot air rework station.
このアンサーは役に立ちましたか?
just be careful with the process, it can go horribly wrong if you are inexperienced. look at some of these photos of how badly it can be done.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,863
