メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Do you really have to remove the battery to replace rear camera?
I have ordered a replacement 4S rear camera which will hopefully fix my 4S. In reviewing iFixit and other tutorials for the repair, all mention first removing the battery before proceeding.
Is this actually necessary? The battery doesn't seem to physically obstruct anything with the camera replacement. Perhaps it is necessary to cut power to the phone components?
Thanks,
Steve
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Not necessary. Apple Technician Guide for iphone 4 has the correct procedure. battery is not removed. Actually, the battery MUST NOT be removed for safety reasons. once the battery is removed it MUST NOT be reused. So ifixit disregarded safety warnings, again.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
it's for safety, you don't physically have to. but you dont want to short cut anything else
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for the reply iwillfix, that makes sense to me. When you pull the EMI shield, it's probably easy to short something on the board.
I guess you could also just pop the battery connector up and disconnect the power only. Removing the battery is no big deal, but I figured if my battery happens to be glued down really well then I could avoid prying it off.
さんによる
コメントを追加
回答を追加する
madmaxmedia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 161
