Flash problems
Everything works fine. But the flash is not working, even when it's opened manually.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Look with a magnifying glass at the flash tube do you see any cracks or broken pieces of glass? If you do you'll need to get the tube replaced.
If the tube looks OK - Do you hear the flash charging (makes a high pitch squeal) and do you see the ready light lit in the finder? If not the charger circuit is having problems.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 215
