Can the screen be replaced without replacing the entire LCD?
Can the screen be replaced with changing the entire LCD assembly on the Nokia Lumia 900?
Lara, it is another one of those screen that is adhered together. It "might" be possible with the right tools, but definitely not something that a DIY'er has readily at home. I would suggest that you replace the complete assembly. Check on here for more information. My answer to this is, no. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 2,249
