Can I use this to solder a logic board on my iPhone?
Sorry for my english, but can i use this to solder things on the logic board on a iPhone?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
aaronlitton, depends on what you want to solder on your board. There is not a lot of room on the board and that particular tip might be a bit big. Otherwise, yes, you can use this tool just like any other soldering iron. Hope this helps, good luck.
このアンサーは役に立ちましたか?
thank you :)
Yes,but we have to be very careful about the other components and wires on the circuit board because this iron emits a lot of heat .While soldering a particular component we have to be quite careful about the wires on the circuit board, otherwise it may melt away.Keeping in concern about all these this soldering iron is a must for every repairs and for every electronics repair enthusiast.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 426
