メインコンテンツにスキップ
Amazonから発売されたKindle Fire7インチのタブレットの改良モデルで、1280x800 HDディスプレイを搭載しています。2012年9月に発売されました。このデバイスの修理は直接パーツにアクセスできます。
101回答 すべてを表示
How do I restart my kindle who has fallen on water?
my kindle has fallen in the water now it doesn't work anymore what should i do?
well in fact i opened it to wipe out the water and when i think it is going to start there is nothing on the screen ....
please help......!!!!!!!!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
nadira, you did not tell us how you cleaned your Kindle. The very first thing I recommend is that you do not use your Kindle until you are absolutely sure it is properly cleaned. Disassemble it by using the help of this teardown. Even so it is not a perfect guide, it will show you all the important steps. Once it is apart, clean every part with 90%+ isopropyl alcohol. Do not forget to clean the cable ends and all the connectors. Use a soft brush and isopropyl alcohol to clean the logic board. Once you cleaned it, let it dry for only a few hours. Replace the battery, and reassemble your Kindle. Re-evaluate for any damage. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What do I do it was working fine and then a tiny droplet of water hit it many two or three so all my apps dont work it says i am not connected to the internet when i am. So i turn it off then on again then shut it down and put it in my dresser it has been like four months to dry out but it is still not working what do I do please HELP PLEASE!!!!!!!!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
nadira さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 3,794
