メインコンテンツにスキップ
2012年6月発売。Core i7プロセッサ 、Turbo Boost / 最大1 GB DDR5 Video RAM
596回答 すべてを表示
Water damage to MacBook Pro 15 (A1286)
Hi, I am looking to repair a Macbook 15 (A1286), which had water damage. The issue is with display. The computer boots up, but the screen displays as a series of vertical lines. It will display fairly normally when connected to an external monitor. Apple tested the machine, said that the logic board was ok (but wouldn't guarantee that it would stay that way i.e.. may slowly corrode over time). What parts would I need to make this machine operational again? Cheers Jennine
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
"fairly normal" external display - anything other than normal hints at VGU (VGC) chip (logic board) damage. I would start with cleaning and replacing the data display cable (it's the least expensive and involved repair).
Good Luck.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Try using contact cleaner on the connections to the LCD?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I would take it to *apple* because they are the ones who made it. They could probably fix it. If you don't know where to find Apple, all you have to do is google their destination that is nearest to you at www.google.com
このアンサーは役に立ちましたか?
スコア -1
1件のコメント:
Mary liquid damage is not a covered "repair" under Apple's (or most other electronic) warranty and remember this is the DIY repair forum...
さんによる
コメントを追加
回答を追加する
jennine さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 1,085
