Samsung Galaxy Ace S5830 screen replacement
Replaced screen on Galaxy Ace S5830 and all looks normal except it doesn't respond to tactile commands. Can anyone help please ?
malcolm watson, double check your work. In particular, check the connector on the back of the bracket. Make sure that it is properly seated and that the cable is not tore.
Hope this helps, good luck.
このアンサーは役に立ちましたか?
my touch respond only sometimes. The connector indicated by oldturkey03 in my phone is ok but nothing...
このアンサーは役に立ちましたか?
Mi telefono no reconose mi chip y no me deja descargar cosas me sale memoriia insuficiente y el chip no figura la red o señal
このアンサーは役に立ちましたか?
The digitizer doesnt work! Please check spec S5830/S5830i (this no work for s5830) but is twin.
Check the digitizer chip is synaptics.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 5,220
