Can I fix charging port?
I dropped my tablet on it's corner. The screen didn't break and everything works fine but it won't charge now. Can I replace the charging port, should I pay someone else to, or should I just watch for a replacement tablet?
You can def change the charging port. I think it is soldered directly to the board so a skilled person would need to do the job.
このアンサーは役に立ちましたか?
When I plug sync cable in for charging my Tab 2 will not turn on. It just shows a picture of the battery where it is trying to charge then the screen just go blank. As long as i have the cord pluged in it goes off and on the whole time.
このアンサーは役に立ちましたか?
My charger cable was wet and i plugged my tab in to charge. can i just change the port on my tab? Wil that fix the problem because my tab does not switch on.
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 7
過去 30 日: 7
今までの合計 10,419
where would you order the part from?
george さんによる
