iPhone 5 DIY battery replacement, warranty void?
Hello everyone,
I have a black iPhone 5 16 GB CDMA model and it was working fine untill recently. I was charging my phone, and then i moved downstairs so i took my phone plus cable with me. Olugged it in my PC and suddenly it wasn't charging anymore! I took my wall plug and got the same problem so i turned my phone down, i only had 4% left and figured i would be better off with little charge than with no charge at all.
When i plugged my phone in again after powering it down i got the 'charge your phone screen' with the wall plug sign and electricity. The battery on the screen blinked 3 times and then turned black. I looked on the internet and this means that it isn't charging, but apparantly it does recognize the lightning cable. I tried with another cable and with a higher powered iPad wall plug but the same problem occured.
So here comes the problem, i am still under warranty BUT my phone is jailbroken. Normally i wouldn't have any problems with warranty by just doing a restore begore sending it in, however i can't charge my phone and therefore can't perform a restore before i send it in.
So I figured, hey, i just temporarily change the battery, perform a restore (hoping that my computer will recognize the phone, which is actually a second point of interest) and then put the old battery back in to bring it in for warranty. Because i couldn't find any warranty stickers orso in the guides to replace your battery i though that Apple wouldnt be able to notice.
I want to be completely sure though, and thats why my question is 'can Apple tell that i replaced my battery temporarely and will it void my warranty? Or another question, what will happen if i just give my phone jailbroken to them? I am not able to charge it so maybe they're not to and will replace it?
Thanks in advance!
この質問は役に立ちましたか?
1件のコメント
Okay so i opened the device to remove signs of jailbreak and then went to the apple store, they opened my device and didnt notice anything! As long as you're careful with the components inside the phone you should be O.K. !
Jochem さんによる
