メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
締切られた回答
Why home Button unresponsive after I replaced the ribbon cable?
I bought the home button ribbon cable to replace it on My itouch 4th gen. I followed the directions exactly like I was supposed to but when I turned it back on the home button sill didn't work. It clicks like it's supposed to but it is not responding. What did I do wrong?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Maybe you've broken the ribbon cable connector, it is very VERY frail.
But before you change it, it was working sometimes or not?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
It didn't work at all. The silver button on the old ribbon cable was completely gone. It felt as if it was jammed.
さんによる
Sorry but i noticed only now that you are repairing an ipod, and not an iphone.
You may have done 2 mistake.
1-You haven't fitted fine the ribbon on the steel mid plane, or you haven't placed fine the mid plant on the ipod.
2-You have broken or you have dirtied the contact.
Maybe you could also have fitted a broken parts but it is very unsual. Unmount the device, try the button with a tester and when reassembling take more attention to put the ribbon in correct position, and clean the contact between the ribbon cable and the logic board.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 86
