メインコンテンツにスキップ
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
20回答 すべてを表示
Dead netbook except leds flash once when power supply plugged
Hi,
my laptop is a packard bell dot (same as the acer aspire one zg5) equipped with a hannstar j mv-4 94v, I disassembled it to fix a wireless module problem, then when i assembled it back and put on the battery the power and charge leds flash for a second and nothing happens when i try to power it on.
same reaction happens when i plug on the power supply or put on the battery.
even the battery doesn't seem to charge anymore (its indicator just flashes for a second as i said)
here's a video: http://youtu.be/ZpjB0Q9bVkU
any help or suggestion?
Thanks,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
moeboe, if it worked before you did the repair, I would suggest that you double check your work. Make sure that all the cables and connectors are properly seated. Check the DC jack to make sure it is not loose on the board. Check your AC adapter and make sure it supplies the right voltage.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
thanks old turkey,
i'm actually trying to power on the motherboard only (without keyboard, screen...) and there's only one ribbon cable connector in it's place and there's still no working evidence.
any other suggestions?
さんによる
コメントを追加
回答を追加する
moeboe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,129
