The Motorola Droid RAZR Maxx is a version of the Droid Razr carrying a higher capacity 3,300mAH battery.
jtoneal47 @jtoneal47
評価: 1
投稿日: 2013年4月4日
Do you have to remove the exterior screws to remove the back cover of a Razor HD? Other than prying apart is there anything else to be aware of?
Thanks
この質問は役に立ちましたか?
oldturkey03 @oldturkey03
評価: 811.9千
1.2千
920
2.4千
jtoneal47, yes you do. Check on here for a teardown. Even so it is not a complete guide, it shows all you need to do to disassemble your phone. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,239
