How can you fix the laser
how can you fix the laser in your game cube
この質問は役に立ちましたか?
michael, you are not very descriptive about what is going on with your game cube. The first thing you could try is to increase the power to your laser. Follow this guide. Just be moderate, you do not want to burn it out. The other thing to try would be a recalibration of the lens. For that follow this guide. After that I'd suggest to replace the optical drive. Hope this helps, good luck.
ガイド
難易度:
中レベル
30 minutes
ガイド
難易度:
中レベル
20 - 25 minutes
このアンサーは役に立ちましたか?
Have you tried cleaning the sensor with a terry cloth and some rubbing alcohol?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 30
今までの合計 1,899
