メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
trying to separate display bezel from rear panel.
Trying to separate the display from the rear panel. Removed two screws and placed a suction cup on display. Instructions says it may take a bit of force to separate. My question is: do I have to hold the rear panel a certain way? Every time I apply force with my right hand, the phone slips out my left hand. How do I hold the phone so that the display separates? Any help is appreciated. Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Hold the phone with your left hand, making sure your fingers wrap around the chrome bezel but not onto the screen. Put the suction cup on the screw end, and place your thumb at the other end of the screen. Put your index finger in the suction cup ring and pull up. I've never had one that wouldn't come up doing it like that.
Now if the screen is cracked...it's a different story. Most people make a duct tape handle to lift the screen up. Apply duct tape to the cracked area at the bottom, and really secure it on there. Make a little handle out of the tape, and lift as said in the other way.
Good luck!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for you advice. Holding the phone the way you described works. I was able to get the screen off. Thanks again.
さんによる
No problem :). Glad I could help.
さんによる
コメントを追加
回答を追加する
john lim さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 5
今までの合計 155
