メインコンテンツにスキップ
iPad Miniは7.9 インチのディスプレイで、容量は16、32、64 GBがあります。
630回答 すべてを表示
Battery says charging but remains at 1% after digitizer replacement
Hey everyone,
I replaced two ipad mini digitizers. These were the kind you have to solder. I used a stereoscopic microscope which made things a bit easier.
But it turns out that one of them will not charge afterwards. It shows that it's plugged in with the icon in the top corner and it doesn't say "Not Charging". I'm plugged into wall (not PC) using original lightning cable.
Digitizer was not working and so it was on when I opened it. When I got to the battery push connector, I made a stupid mistake of using my metal tweezers to disconnect and I saw a tiny little arc. This happened to me once before inside an ipad 2 without issue so I didn't think anything of it. Should have learned from my previous mistake.
At this point I am stuck, so I need your insight. Do you think if I replace the battery it will do the trick? I'm short on time, customer is losing patience with me.
Some tips when soldering the digitizer, a little solder on the IC board's pads goes a long way. Also, on either side of the digitizer flex there are little square holes that allow you to line things up. If you tap them with your iron, the plastic will burn up and it becomes very easy to line things up. I kept it lined up with Kapton's tape directly onto the table underneath the field of view of my scope.
Thanks for your help,
Mark
Southern California
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
That's part resistor is on the board or the battery I can fix replacing batery?
さんによる
コメントを追加
9件の回答
ベストアンサー
Here is an update in case someoneelse finds themselves with the same problem. I found a small resistor that had come off next to the battery push connector. Was able to resoler it and battery charged again. Barely visible without microscope.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
i have a different problem, my ipad mini says it is charging, then i left it for 30 mins and then it's still stuck to 1%, i tried to shut it down and plug it again but it really wont charge. can you help me with that?
さんによる
コメントを追加
Hi Mark,
I got my ipad mini fixed by a local mobile repair shop. I ended up having the damaged digitizer replaced with the very same battery charge issue, It says charging and stays at 4%. I gave it back to them to fix. However, I think they have no clue themselves as they are delaying it.
I came across your nice article and the fix. I am suspecting the same case with my ipad as well. Would appreciate if you can share a picture with me of the resister that needed reordering. Probably I can take this info back to them to start looking into it from this perspective.
My email id is syedazharpasha@hotmail.com
Appreciate your help!!
Regards,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello guys...it seems that i have a similar case with my ipad mini where the resistor got torn out...does anyone by chance know the resistance of that resistor? Maybe i can put a new one in there
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
anyone know the value of resistance losses?
mvh
さんによる
you can take the resistor out from the babseband area of iphone 5 and for the big capacitor under the lcd connector of iphone 5
さんによる
コメントを追加
Its just to the left of the connector if holding the device with home button towards you. Under a scope you will be able to see it missing. If you don't have the resistor, you may want to just put a solder ball to bridgethe connection. DDon't quote me but I think a bridge of solder will work fine and not cause any problems.. That device went back with customer shortly after and unfortunately I never got photos. Good luck! - Mark
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hi guys i removed the resistor on an old blocked board to replicate the fault and you can indeed just solder the pads if the resistor is missing
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
I have a similar issue. The ipad mini will not charge. It won't even show the charge icon on the screen. I could the charge lowering so the charge was moving but only downwards lol
Has anyone any idea of the resistor values?
Any help appreciated.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
Thanks to Jessa, it seems that there is a power regulator 1608A1 chip on the U1300 position on the ipad mini motherboard. If the charger does not charge, or does not connect to the computer, then this chip could be at fault. I believe this is also know as the U2 Chip.
There must be a way of testing to see if it is blown though?
Thoughts anyone
さんによる
There also seems to be a second usb charging chip FDMC6683 on the Q8104position on motherboard.
http://www.auctiva.com/hostedimages/show...
さんによる
I'm sure you've done this, but changing dock connector is also something to rule out.
さんによる
I am planning on inserting a cut lightning flex into the ioad mini dock and check continuity between the wires and the soldered pads. This shouid work in theory or would it ?
さんによる
I'm not sure it is that simple. There is a lot of info that flows through the dock connector flex.
さんによる
1以上のコメントを表示
コメントを追加
i have a different problem, my ipad says it is charging but then i left it for 30 mins and then it is stuck to 1%, i tried to shut it down and plug it again but it isn't really charging what will i do? im really freaking out :|
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
If it has been opened, then you are missing the battery filter just like in this thread. If it has never been opened you have charging if failure
さんによる
maybe there is something wrong with the charger?
さんによる
its definitely the filter
さんによる
コメントを追加
Yea, this is a known "feature" and pretty sure that U2 if it is genuinely bad will also get hot when you attempt to charge . Ipads like many fruity devices detect the presence of specific resistances on the two data pins, if any one thing is wrong it won't charge.
Did read somewhere that if you've got a board with damaged pads on the digitizer its possible to get one with extended pins pre-cut at the factory to spec so you can micro-solder it in place as normal eg with solder paste and stencil.
The solvent used is quite important as plastic will deform and melt if you try acetone, MEK or anything like that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mark さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 28
過去 30 日: 107
今までの合計 31,251
