RAM Upgrade - CPU Panic
Hello,
I own a MacBook Pro 15" Mid 2010. Currently I have 4GB of RAM and I wanted to upgrade them to 8GB. So, I bought these:
2 x Corsair 4GB DDR3 SDRAM Memory Module - CM3X4GSD1066
Corsair - Memory - 4 GB - SO DIMM 204-pin - DDR3 - 1066 MHz / PC3-8500 - CL7 - unbuffered - non-ECC
I easily installed them on my MacBook Pro but on the boot I receive errors like "CPU Panic" and other "Non-sense" error codes :)
Are these products not compatible with my MacBook Pro (although the specifications should work) or am I doing something wrong here?
この質問は役に立ちましたか?
2 件のコメント
Hi Andrei, in terms of compatibility everything seems to be fine. Besides the memory upgrade, did you also upgrade your software? What happens if you insert the old memory modules? Do you then get the same errors/errors at all?
Steffen さんによる
I am using OS X Mountain Lion. Now I am using my old memory modules and everything is working fine.
Andrei R さんによる
