メインコンテンツにスキップ
The Toshiba Satellite L300 was a notebook designed and sold by Toshiba that came with a version of Windows Vista. They were sold around May-June 2009 and while ineligible for the free 7 upgrade, time past and upgrades are unclaimable now, run 7 home premium well without upgrades mainly because of Vista's resource hog quality. Also known as Toshiba Satellite L300-04P (PSLB8C-04P01X).
20回答 すべてを表示
Is there a bluetooth in this particular laptop?
If it does how to operate it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
4 件のコメント
First thing you want to do is to check in your device manager to see if you even have a Bluetooth module installed. If it does let us know so we can help you out further, if it does not, you can always get a bluetooth dongle to add that function. Most did not have it installed, but give us your exact model number so we can try to find out. Your model number is on a tag on the bottom of the laptop.
さんによる
thanks for your support..my model # is Toshiba Satellite L300 PSLB0A-08C022..i did go to the control panel and i could see the bluetooth icon but when i open it..there is just blank page.
さんによる
I would delete it out of device manager and reinstall the driver. If you have the resource disk that came with your computer , it might be on there, if not then download it from the Toshiba Website. Which OS do you use?
さんによる
Mine has the same problem my model is Toshiba Satellite L300 PSLB8E - 0TG00HAR
さんによる
コメントを追加
2件の回答
ベストアンサー
Please give us the products full name ex L300-11 so we can check it better, but one of my friends has an l-300 and im pretty sure it is intagrated with the wireless driver, also see users manual
http://static.highspeedbackbone.net/pdf/...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
Check Toshiba's Site to see if it does, it may have a slot for a Bluetooh radio, if so you can purchase a radio to enable Bluetooth compatibility
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
laurence chand さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,983
