メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
Broken Front Glass on Galaxy 3
I want to replace the front glass on my Galaxy S III. Is there a guide for doing this? I found a new front glass on line. The repair appears to involve using a heat gun and looks complicated.
Thanks,
John
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
Is it just the front glass or glass and LCD?
さんによる
Just the front glass, everything works perfectly but the glass is fractured. Dropped it on its edge.
さんによる
It shouldn't be too difficult. If its anything like the other ones it will just be time consuming with the heat gun prying the front glass off (after all the other steps of course!).
さんによる
Thanks, I did find a video on Youtube but not here. Looks like parts / tools are $30.00 or there is a local shop for the whole repair $150.00. Tough choice.
I'm tempted to try it.
さんによる
コメントを追加
3件の回答
ベストアンサー
John, here is my answer to a very similar question "The glass is fused to the display, and the display to the Galaxy S III's frame. These are most certainly very difficult to separate. You are more likely to break the LCD as well by even trying. Even if you could do it successfully, you will still have to find a way to "glue" them back together. I don't think there are any cheap options at this time." Check on here for more information.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
http://www.youtube.com/watch?v=25C3ymJdk...
Here is the youtube video I watched. The glue to put it back together is a double stick tape. It looks a bit tricky to me and I'm leaning toward paying the $150.00 to have it done. Parts, tools and tape are only $30.00 (Amazon) so I'm tempted to try. I'm good at repairing things....
さんによる
コメントを追加
It's really not easy to just replace the glass lens since the glass lens is glued on the screen, which means it's difficult to separate it from the screen. You'd better repalce the whole screen or go to the repair shop to replace the glass lens.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have seperated the glass from the lcd twice. the first time i screwed up the second time was perfect. so yes it can be done but its not so easy.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,335
