Why is the expresso shots not hot?
Expresso shots not hot mach says select beverage heater? How do we do that?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
What temperature are your shots coming out at? To accurately measure this you need to place an instant-read digital thermometer directly in the stream of water coming from the brewhead (leave the portafilter off); temperature should be around 200 F. If considerably cooler you may have calcium buildup in your boiler that's preventing the machine from heating properly, and in that case you should descale it with Durgol or other citric acid-based descaling agent.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 288
