I cant turn on my iPhone after removed from charging?
I cant turn on my iPhone after removed from charging and I just used it for 2days because its new.How was it?How can I fix it?
You can try plugging it in again to see if your phone responds to the power surge.
You can also try the soft reset function - hold the sleep button and the home button at the same time for at least 10 seconds and see if anything comes up. Sometimes my screen doesn't display which can make it look like the phone isn't running, but for me, it has been, it just needed to be rebooted to fix itself.
If that doesn't work and the phone is new, call up the place you got the phone and get it swapped on warrantee asap. The longer you wait, the more excuses they will be able to give you.
このアンサーは役に立ちましたか?
Yeah that"s true that's why i return it back immediately..tnx by the way..
Has it been taken apart before? Maybe the dock connector on the inside connecting to the motherboard isn't taking the power to the battery, just a thought; could be wrong. But if it's new then it's probably best you take it back instead of opening it up.
このアンサーは役に立ちましたか?
yeah... i return it back...tnx.
過去 24時間: 2
過去 7 日: 7
過去 30 日: 7
今までの合計 455
