メインコンテンツにスキップ
ネップブックも時として修理が必要です。このガイドで修理をして長く使い続けましょう。
503回答 すべてを表示
Samsung N130 does not boot up, 3 short bleeps then inactive screen.
I went to start up my Samsung N130 Netbook a few days ago and on it starting up there were 3 bleeps leading to nothing....
Nothing shows up on screen at all, the machine is running as i can here the fan etc. i have checked harddrive and am going to check the ram. Any other suggestions as to what it could be? Or anyone who has had same problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
patyershants, try entering the BIOS with [F2], then save BIOS defaults with [F9], and then save and exit with [F10]. You also want to check that the memory module is correctly seated. Try the computer without the battery. Remove the battery, the memory and the AC power. Press and hold the power button for a few seconds, then reinstall the memory and the AC power only. If that does not accomplish anything you may need to try a CMOS Reset. To reset your CMOS you should have some power pads under your memory module. Remove the memory and look for two pads with a marking like "RTC reset". Shorten those, and only those, with a pair of tweezers or similar instruments. See what you get. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hey thanks for the reply, but as i said when i switch the power on i get three bleeps then absolutly nothing happens, so i cant enter any BIOS.
I have replaced and checked the ram and harddrive, took the battery out and power on just with the mains. And nothing seems to happen when i try reset the CMOS, i got a change in beeps but it soon went back the the usuall 3 that i have been getting
さんによる
If you went through all the steps, then the three beeps are indicating that you have a video error. Not sure which BIOS you have but it is possible that your laptop has the Nvidia GPU which has failed.
さんによる
Ok thanks for the help man :)
さんによる
コメントを追加
Same thing happened to me, to find out that my proccessor inside was loose, i took it apart and it was a see able problem, i took a bit of a card and popped it right into these little pads, to secure it.. right after doing so it worked perfectly, its something on the inside. Otherwise i dont know how else to help you, your best bet would be taking it apart, its not that hard at all, nothing to mess up. all you need is a tiny screwdriver
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Actually might be a different machine: the N130 has soldered CPU. If thats come off then you have bigger problems! That said some folks have found a reflow helps but it won't last. The problem could actually be a failed Atom CPU as there were a lot of early ones that had the clock bug.
さんによる
コメントを追加
Same problem here. Maybe worth mentioning but the CMOS battery on these is a small disk with wires attached.
I have replaced it (2.6V) but alas no change.
It might be worth replacing the 25L16 BIOS IC if all else fails as this has unbricked a few netbooks here.
Also check core voltage as if this is too low then it won’t work.
Hint: these chips are often used on older netbooks and have a scrapper (Toshiba 630996-001) that has already donated its power switch to the cause.
The fiddly part would be flashing this and recommend the chip be wiped twice with zeros to make sure before flashing it with a known good image. You can just buy a chip as well from ze biosman.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Also on my 130 found that if the input MOSFET (part of the power step down circuit) fails short then it can stop booting. Something about an excessive load on the 3.3V supply?
さんによる
Also I finally sourced a new board. Looks like its not just the MOSFETs that are hosed, possible overheating did it in. If anyone has a spare pair of brackets for the screen please message me! thanks! On the flip side I can now try out my induction reflow method as this is a great way to lift iron containing QFPs on motherboards etc as long as you do it carefully enough with plenty of pre-heating.
さんによる
コメントを追加
回答を追加する
patyershants さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 14
今までの合計 3,237
