メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
How do I install my Backlight IC coil thing? Any tips?
I dropped my phone in water, and now my backlight doesn't work. I heard that I should replace the backlight on my phone, but even if I buy the backlight IC or coil thing, I don't know how to install it. Do I need to know how to solder? Or is there someone that I can be referred to that can install it for me for cheap? Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi Colton,
There might still be water in your iPhone. Therefore, I would first open the iPhone, would remove the motherboard and soak it in isopropyl alcohol (90%). Also, clean it carefully with a small brush, also the LCD/digitizer unit. Let everything dry for a couple of days before you put it back together. Then see, if the backlight is still bad. For disassembling it, follow this guide: iPhone 4 のロジックボードの交換
In case the backlight is still bad, here is what you might end up needing:
http://www.ebay.com/itm/IPhone-4-backlig...
You need to desolder the coil and (possibly) the IC on the motherboard. If you are skilled in soldering, I would try it. If not, I would look for a place where you live that is able to fix it.
I hope this helps.
Steffen
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 540
