メインコンテンツにスキップ
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969回答 すべてを表示
締切られた回答
Black screen, sometimes moving it let me see something
Hello
There is this Toshiba Satellite C660-1MG and the screen is black when I turn it on. From the border there is some white moving.
Moving the screen (opening and closing it again) one time on a million let me see something, but then it makes a little movement and freezes and goes white or black.
What can be broken and how can I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Most probably the connector that goes from the screen to the motherboard is broken try pushing the bottom of your screen a bit harder with your fingers to see if it flickers back to life if it does then u need to change the cable, its not that expensive usually.
Also try to connect an external monitor to see if u have video signal
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 317
