メインコンテンツにスキップ
2008年10月発売。2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duoプロセッサ。
376回答 すべてを表示
Is possible to swap my logic board with a newer one?
Hello everybody,
My logic board (Apple Part #: 661-4834, 661-5098, 2.4ghz, as i discovered thanks to ifixit) is suddenly dead.
So i decided to buy a new one but i want to know if is possible to use a newer one, like the 661-4836 2.8ghz or even the 661-5213 (or whatever is possible!).
As far as i can image the ports and the sd card slot are a problem (except for the 661-4836 because is the same), but there are other issue?
thanks in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
john madden???
さんによる
john madden? what?
さんによる
コメントを追加
1 件の回答
ベストアンサー
If you stay within the same Model number you should be fine. Please give us the last three figures of your serial number or the Axxx number of your machine and we can get you to the correct part. Also why do you think your logic board is bad?
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
The logic board is bad because the computer didn't start at all. Even with the magsafe connect I can't check the battery level. Plus an apple repair service told me that the logic board is dead.
My serial is: w88492ld1g0.
I think that i can change my logic board just with the 661-4836!
さんによる
Apple MacBook Pro "Core 2 Duo" 2.4 15" (Unibody) Specs
Identifiers: Late 2008 - MB470LL/A - MacBookPro5,1 - A1286 - 2255
さんによる
Looks to me like the 661-4836 will work for you.
さんによる
thank you!!!
さんによる
Did the 661-4836 work? I have a bad logic board as well and its the 2.4 Ghz model, I was looking to upgrade it to the 2.8 with the logic board swap.
さんによる
コメントを追加
回答を追加する
damocle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 643
