メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Screw Chart for iPhone 4S
I have seen the screw chart for placing screw as you disassemble the iPhone 4 but not the 4s. Is it the same? Can you provide one for the 4s if not. If it is the same how about a link on all pages that it would be useful on.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
4件の回答
最も参考になった回答
Hey Christopher,
Try using this screw chart http://irevivespray.com/iphone-4s-screw-... for the iPhone 4s, print it out and your on your way :-)
Regards
Chuck
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I like it. I will use it and try to recreate one
さんによる
コメントを追加
Christopher Chesler, each one of the guides on here list the screw size when they are removed. If you look at the guides and write the sizes down, you should get a pretty accurate list. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Christopher - Help others out and post your results on the guide ;-)
さんによる
Thank you. I will defiantly make a chart as I go and post my results for future reference.
さんによる
Sounds great. It's a guide that a lot of people will appreciate.
さんによる
コメントを追加
Hello all,
These charts are all very good,but what do
you do if you need to finish off somebodies work
when you did not tear it down please.
Regards
Update
Hello again,
I do not know how I got to be in this
position,it was me who posted above question.
The charts I find are very good if you have one
before you start,but if like me,you are finishing
somebody elses work,they do not help.
What I would like to find,is a chart with a
number for the screw,then the numbers put
where the screw goes.If somebody would do
this it would make for some very happy people.
I obviously include myself in that.
Thank you for the chance to post my
thoughts on your site.
SYN
Update
For oldturkey 03
Being a newbe I could not tell the difference
between a 1.5mm and a 1.7mm screw that is
why I would like the chart described.
Thank you
SYN
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
EXACTLY SYN!!! My cat jumped up onto the paper with the screws on it (non-magnetic...I learned THAT lesson the hard way!). I have a digital vernier caliper and it's STILL brutal trying to figure out the minute differences in screw sizes. I don't know how anyone can manage to get the screws in the right places without a digital caliper.
There is SUCH an EASY solution to this problem....(pleassssse ifixit.....colour code the screws with the corresponding colour-coded holes on the magnetic mats!!! Even if it was done with Sharpie markers on the ends of the screws it would be IMMENSELY helpful. I am dreading putting this phone back together....
さんによる
コメントを追加
It sounds like you have a handful of screws that all ya know about is they go to THAT iPhone 4s. Am I right? If so, if you plan on doing this much in the future a good tool to have around is a quality set of digital calipers. Then you can measure the screws and match them up to the sizes listed in these guides. It's unfortunate the extra worK you will have to do, but it's a pitfall of picking up where someone else left off.
Best wishes and good luck. Just take your time because it will be tedious and time consuming. But in the end you will have them all where they belong and you already know how important that is.
Dave
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Well Dave, I have a digital vernier caliper and it's STILL a brutal task to try and measure those screws. I have measured, measured again.... and again... and again... Those tiny increments are just too difficult to ascertain. As I suggested in previous comments, it would be SO helpful if ifixit could colour code the screws with the corresponding colour-coded holes on the magnetic screw map.
I would do this for other people if I could, but I'm just not confident enough that I have the right screws...
さんによる
コメントを追加
回答を追加する
Christopher Chesler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 25,287
