メインコンテンツにスキップ
Built-in Beats Audio™ delivers uncompromised, studio-quality sound for your music, videos and gameplay. It’s a powerful all-round performer too, with dual-core power, a brilliant four-inch, crisp display and a class-leading camera
7回答 すべてを表示
Cracked touch screen panel
My sister has a HTC Desire X phone.
Link: http://www.htc.com/nl/smartphones/htc-de...
It has a crack in the top screen only. The display itself is not damaged.
Can i replace the top screen. Where can i buy the parts?
Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts.Thanks-Kiran
さんによる
am using htc dsire x,my power button is totaly damagd,how to replaced the buttn....
さんによる
Display and touch is damaged
さんによる
My phone modle is htc desire.can I replace only a top screen glass.bcz touch with lcd display 's cost is high
さんによる
My phone is htc desire x in which display has been cracked but touch s working.. Nd battery has a poor problem.. Can u replace battery nd display????
さんによる
コメントを追加
9件の回答
ベストアンサー
The screen can be replaced.
you can find the part on ebay:
http://www.ebay.com/itm/Touch-Screen-Dig...
cheers
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
最も参考になった回答
You will need an lcd separator machine to separate the lcd from the glass as they are glued together and it needs to be put on a special hot plate. Tutorial and lcd separator machine reviews can be found at www.lcdseparatormachines.com if your interested..
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts...pls hlp me..
Michael
さんによる
コメントを追加
Be carefull! Hade the same problem with my sisters phone. I first tried to replace the Digitizer Glas, but its full glued on the LCD screen when I tried to seperate both the LCD broke. You have to replace the whole display unit. I bought them from ebay. Didn't find it on ebay.com but on the german site. It's about 90€
http://www.ebay.de/itm/Original-HTC-Desi...
Even this is the whole TOP-Unit it was still not very easy.
Hope I could help!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello
I´ve found it on ebay more cheaper.
http://www.ebay.es/itm/380739140385?ssPa...
I´m waiting for receive it and create a guide to all of you!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i needed a new glass for mine which is a htc desire 310 and found my glass on ebay it's coming form hong kong
さんによる
コメントを追加
hi, yes be careful , Bernhard is right the digitizer glass is stuck glued with the lcd screen and it broke with me as well so i needed to change the whole display unit. i found it on ebay and it's cheap :
http://www.ebay.com.au/itm/for-HTC-Desir...
i ordered it and still waiting for it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Had anyone got some kind of repair-guide?
I only found this video:
https://www.youtube.com/watch?v=hzRsLDah...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hello, I´m working on a repair guide, hope to finish it on this weekend.
さんによる
コメントを追加
Did anyone bought some not original lcd and glass replacer?
I'm not sure if they are worth anything.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hello, yes, I have bought 2 lcd+touch non original ( but with the HTC logo) and they works fine. The point is to glue properly the piece to the phone, because sometimes it comes out.
さんによる
コメントを追加
how to stick the digitizer to the display\front pannel
.please help
mine is not sticking
i cleaned it with glass spray also
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
what you have to do is heat the screen up with a hair drier or hot blower and then remove the screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 24,173
