メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
No Service when 3G is enabled.
Dear iFixit,
I am having a problem for a bit with my old 3GS: I get very poor connection when 3G is enabled. Basically, I have some network for a few minutes (10-15, it varies) then switches to "searching" and then "No Network". I usually don't get any network back.
It is interesting to note that when 3G is off, I have absolutely no problem getting a stable GPRS/EDGE connection.
I am currently running iOS v6.1, but I have this problem for ages.
Therefore my question is: Is there a different antenna for 3G and EDGE/GRPS? Would you recommend changing it?
Regards,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Hello,first off all sorry for bad eng. but ill try to help you
So i saw a lot users od iphone have problem with iphone 3g/gs. No service on 3g network or when its off,i have that phone also and i have solution that worked 100%
problem is on signas switcher that is located on this picture you can see them: lower part of iphone.
http://i87.servimg.com/u/f87/13/27/39/62...
So here it is,take a hair dryer,a turn it on,heat this chips for about 10 sec,then whit your fingers push chips on logicboard,get iphone back on,go to settings-reset then reset network settings,and its workig :)
if its now working try to heat and push chips again
please share this solution becouse i cant see any other solution for this problem
and please correct my words if there is something wrong
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
jurica, nice answer, but can you describe the location of the "signas switcher" a bit better?
さんによる
I do it by the way,but it does not work.
I must push chips on logicboard more powerfully?
さんによる
コメントを追加
Hi,
i had the same problem with an old 3GS. It was an error in the logic board, without a chance to fix it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
can this problem be solved in same manner for android phones?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ace Spizzer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 8,302
