メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
iPhone 4S Serial Number Question
So, I had my iphone color changed from white to blue... But dropped it and had the person place my original white screen back on so I can take it to Apple since my earpiece and speaker don't work well since dropping it... But for some reason they are telling me that the serial number in Settings>>>General>>>About>>>Serial Number and the serial number inside of the iphone don't match. Not sure what the guy did or what piece of mine he might of switched whether on purpose or by mistake but how can I know where the other serial number is located? Need help please...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
rayrod354, it is on your sim card tray, see attached image from here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Aha.... I knew about the sim card tray but I think that's what happened... The one that is on the flex cable cover is that one that must of been confused and put wrongly on my phone...
さんによる
コメントを追加
iPhone 4S Serial Number is also printed on the small Flex Cable Cover (held down by two screws) of the Dock Assembly Flex Cable Connector to the Logic Board.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
さんによる
コメントを追加
@Brad means this
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Matthias is absolutely right about the information. Now your phone warranty is avoided due to Unauthorised Modification. if you have same matching serial no . you can try to request them if they understand they can replace the phone. otherwise change the phone . Sell it and buy the new one .
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 2,812
