Water Dripping Sound MBP 13" mid 2012
Hi guys. i have MBP 13 entry level (non retina)
my mbp has a water dripping sound (also sounds like "tok" / "tik" or "click"). my laptop fell from a knee level height from my bed. bottom facing the floor. (accidents do happen)
it makes the sound every two minute or so. its random. sometimes 3-5minutes. what would be the causing problem? ive research a bit and read that it might be the hard drive. it never hangs / lags when i use it even when playing. please help me. will switch to SSD if the problem is the HDD. but if it can be fix. way better. thanks
3 件のコメント
EDIT: i bought crucial m4 256 SSD ... im installing it then at the last screw (using t6 torn) i mess up... it got wrecked after applying a little pressure because its too tight... currently looking for HDD screws.. will let you know it everything went well
Darrel さんによる
PROBLEM SOLVED: i replace my HDD to SSD. no more water drippig sound. thanks for all who help me. will plan to change my optical drive to HDD soon since my stock HDD has the problem and will get another HDD. thanks again
Darrel さんによる
PS: btw i use a long nose plier since the head screw has mess up.
Darrel さんによる
