メインコンテンツにスキップ
モデル番号A1137/1、2、4GB容量/カラーオプションはブラックとホワイト
68回答 すべてを表示
I think I fried my iPod with the wrong power source.
I plugged my iPod into my inMotion speakers, but it turns out I had the wrong power adapter connecting the speakers to the wall. The speakers say DC IN 5V, and the adapter says 9V 1.11a.
I didn't know it was the wrong adapter until I inserted my iPod and the speakers (still off) started making a buzzing sound. The iPod then displayed: Connect to iTunes to restore. When I felt the upper back case, it was hot, and now it won't turn on at all. I've tried connecting to iTunes (nothing happened), reseting (nothing) and trying another power source (nothing).
What part of my iPod do I need to replace?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
mtbiker90, I'd start with the battery. Hopefully it is just the charging circuit of the battery that received a jolt of extra power and not the power management IC etc. Use this guide to replace the battery and see if it works. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'll try that.
Thanks!
さんによる
コメントを追加
I tried replacing the battery plugged the ipod to the charger nothing indicated in the screen waiting several hours still nothing I think I burned out the ipod circuits hard drive or whatever makes it tick the replacing the battery was easy but didn’t solve the issue what should I do next
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
aaa さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 7
今までの合計 600
