iPhone 3G replace home button instructions
I need instructions on replacing the home button on iPhone 3G.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You can buy a home button with flex or just the flex on eBay . Replacing is very straight forward.. Simply take flex off back of home button and then put New flex on. You need to place flex through hole in midframe. Sometimes just lifting prongs on back of home button flex is enough to fix non working home button. Try this befor you buy new. Flex is cheap but if you don't have to replace it, it's even better!
このアンサーは役に立ちましたか?
How to replace/fix home button?
If this answer is acceptable please return and mark it.
Good Luck,
N.
このアンサーは役に立ちましたか?
I want more help on this, where can I get a home button and how will I open and fix it
このアンサーは役に立ちましたか?
Please start your own Question not reopen old ones! You're more likely to get an Answer- Only Answers belong here.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 30,436
