メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
What do I use to "reglue" my wifi antenna?
A while back, I broke my IPod 4g screen, so recently I bought a new screen and replaced it. Worked great. However, in the process, I unattached and unplugged my Wifi antenna...It was held down with some sort of..adhesive substance. I plugged the antenna back in but now my Wifi goes in and out. If I hold it down with tweezers, my internet connection is fine, but once I let go, I slowly start to loose connection. I figure that I need some sort of glue to keep it held down, but I can't find exactly what I should use... Anyone know? Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
I would use some very very thin electrical tape, or you could find an equivalent to it. Basically the reason your wifi goes in and out is that the iPod uses the outer metal case to strengthen the antenna, hence when you press it against the case it works fine. All you need to do is find something that is NOT conductive, and is small and adhesive enough to keep it secured.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Would liquid electrical tape work? I was looking at this: http://www.amazon.com/Star-Brite-1-Ounce...
さんによる
Keila Black, that stuff might just work. It does fit all the criteria needed, just try not to make a mess with it :-)
さんによる
lol. I imagine myself making more of a mess with physical tape..like accidentally ripping the WiFi antenna cause I taped it down wrong or something. XD but anyways, thanks for the help!
さんによる
コメントを追加
Use Double Sided Tape it will work just fine. Put it between the antenna and the white plastic, not between the antenna and the front panel.
Use the transparent tape.
Do not use the black thick tape, or you will be not able to close the front panel.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Don't bother gluing it or taping it. The way the screen fits there is almost zero "wiggle" room for extra adhesives or tapes. You are risking having the screen sit unevenly and getting possible white pressure points on the screen and worst case scenario you could damage the LCD. Just sit it in the right place and install the screen. I have never had any issues doing it this way, just make sure the antenna is completely connected. You don't want to have to re-open it to fix.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Keila Black さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 6
今までの合計 769
