メインコンテンツにスキップ
Samsung Galaxy NexusはGoogleの最新デバイスであるNEXUSモデルと同じグループです。HD Super AMOLEDディスプレイにカーブしたディスプレイ、そしてAndroidバージョンは4.0 Ice Cream Sandwichです。
41回答 すべてを表示
締切られた回答
Where is the processor located?
To begin from the beginning: Using flashlight turned on for about half a minute on my nexus I dropped it from 1 meter height, the backcover and battery came apart. No visual damage to the screen or body at all. After assembling it the phone never turned on. No indication of charge when connected via USB cable to a charger or computer. No effect when removing and inserting the battery with connected USB cable. The repairman told me the electric contact between the processor ball grid array and the mainboard socket might be damaged due to such a drop. He also told me he has no suitable stencil to re-attach the processor. I asked him where the processor is located and his answer was - on the motherboard's back side and the only way to get it work is to get him a broken phone or a working motherboard to assemble a working phone. But I failed to locate the processor there using your pictures in Step-by-step Guide. What would you advise?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I made more research and found the processor was marked yellow on this image http://guide-images.ifixit.net/igi/noJOb...
さんによる
コメントを追加
1 件の回答
ベストアンサー
Take it all apart using the guides and then reassemble. It's probably just a connection, but may be a broken BGA in deed. Your good screen is worth a lot, so try to buy a SGN from eBay with a broken screen. Replace it with your good one.
I don't think it's the BGA because it's held in place pretty well and there are lots more things to fail first. Compare pictures of yours to the take apart. good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 379
