メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
driver headlight is dim
i have a problem with my driverside headlight.my daytime lights work until i put my switch on then my driver headlight is dim, when i turn my lights off my daytimes dont work and my headlight indicator light blinks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
andre, check your light bulb to make sure that you have the right one installed. Check your wiring harness for a short. Check your connectors as well as relays for corrosion and make sure that you have proper ground connection.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
1st Step:
Test with an Instrument (Voltmeter),
if the correct or sufficient Voltage is supplied at the Bulb.
Measure at the 2 terminals of the bulb.
If your vehicle has a 12 Volt Electrical System, (DC)
the display at the Test-Instrument should read approximately 12 Volts.
Most "Multi-Meters" are able to measure DC-Voltages.
(Keep well and be kind to each other)
Klaus
さんによる
Often the cause is a bad connection at the bulb-connection.
A bad connection is a Resistance for the electrical current.
This causes a Voltage-drop
and the bulb has insufficient voltage to light up fully.
さんによる
コメントを追加
回答を追加する
andre さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 1,490
