メインコンテンツにスキップ
A type of digital audio player (DAP), MP3 players are electronic devices that can play MP3 digital audio files.
8回答 すべてを表示
My MP3 Player is not getting detected.
Hi,
I am unable to switch-on my MP3 player and it is also not getting detected when i try connecting it to system. Please help on this.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
5 件のコメント:
Information on this is difficult to find. Any make or model numbers on your device?
さんによる
When i had one of these back in the day it powerd itself up when i connected it to the PC. Does yours power up ?
Did u forget and old battery in it and did battery acid leak out ?
さんによる
Hi,
when I plug in my digital mp3 into computer USB port it will not detect on my PC but the digital was connected as charging.
さんによる
Hi @ Jaynald Aranas
Was your mp3 player switched on?
If it was switched on, what is the make and model number of the mp3 player?
What is the make, model number and installed OS of the computer?
さんによる
hi i have the same trouble but with "you have to format it before use"
さんによる
コメントを追加
3件の回答
prrasuna, if it does not turn on and is not detected, I would start by replacing the battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It looks like the one I have. I had alot of trouble searching fo information about it as well. I got lucky 1 day and finally found what i was looking for. Try this address ( http://www.manuals365.com/swf/element/gc... ) Hope it helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
prrasuna さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 9
今までの合計 1,424
