ps3 dc connector on motherboard broken..
Opening my ps3 ive Brocken the dca connector from the motherboard. Anyone a solutikn how to fix? ==
Looks linke in the picture.
Seyit Yildiz, you did not show us the connector properly. It appears from the two images you have that it can be soldered back on. You will need a soldering station (soldering in), flux, solder and a good light and a magnifying source would be helpful. Anyhow, with some experience it should solder back on without great difficulty, If the contacts on the connector are still ok. you may want to take a couple good close up pictures and post those. The better the picture, the more precise the answers will be.
このアンサーは役に立ちましたか?
Its the connector shown in the picture. The connections are OK. But i dont really know whether there are special connection point...
Seyit Yildiz, 10 minutes ago • Delete
http://s7.directupload.net/file/d/3149/e...
When you say "there are special connection point" what exactly do you mean? Just checked the link last posted with you answer. Yes, that is the one I was thinking off, It should be straight forward. Can you take some good pictures of your connector and your board so we can see what you see.
Hello guys!I have the same problem on my Ps3 Slim….i tried to disconnect the cable and the connector from the mothernoard got broken and there is no way to solder the connector in the same place.Can anyone help me with some pictures with the solution.In my case i definitley will have to use some wires and make new connections.But i can’t find the Test Points….
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 7
今までの合計 951
Just to verify, you are referring to the DC in connector?
oldturkey03 さんによる
Seyit さんによる
Seyit さんによる
I will post some photos. But on the motherboard there are no soldering points. So in cannot Solder the connector back to the board. Now i need the lines where the connectors are soldered to.II think in have to solder a bridge circuit. I bought a New connector but there are no soldering points. Do you speak german caus in read something about Bundeswehr on your profile.
Seyit さんによる
Yes I do:) once you post an image of your board showing the contacts, we might be able to help you out a bit more.
oldturkey03 さんによる
4件以上のコメントを表示
