MacBook air will not charge
I had a liquid spill on my MacBook Air. Battery would not charge, but computer worked as long as it was plugged in. I changed the battery, but the problem persist. Any ideas?
There is a small piece inside the unit where the magsafe connector plugs in. This part may need replaced. Should be a cheap and easy fix but its something to start with. The water damaged may have fried the part of the circuit that charges but not the part that just supplies power.
Hope this helps
このアンサーは役に立ちましたか?
A small circuit board
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 634
