Xbox 360 S Wifi Card Fail how to fix it?
jaime velasco, if you are sure that your card has failed, you will have to replace it. Here is a guide for it and the part is available at places like this. Hope this helps, good luck.
このアンサーは役に立ちましたか?
have you tried to reset to default in wifi settings
i had the same problem
i reset it to default and it worked
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 905
jaime velasco, what do you mean by fail? What does or doesn't it do?
oldturkey03 さんによる
