メインコンテンツにスキップ
Mid-range desktop PC made by Dell. Model number 4600.
8回答 すべてを表示
締切られた回答
Processor fan wouldn't power on
Recently I tried to replace my processor fan because it stopped working in my dell dimension 4600. When I replaced it I forgot how to install it, however after seeing this webpage on replacing processor fan for 4600 I quickly followed instructions. But still the processor fan would turn on. Please help.
Regards.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
EKMoorhead, take a voltmeter and see if you have power to the connector on the motherboard. There are different versions of this motherboard so check for other fan connectors on the board. If you can not find anything else, and do not have any power to the connector, wire the fan up to your power supply.
UPDATE
let me know if this is the layout of your board. Even with the number's it seems there are different versions out :-)
Update
okay, here is an image with the fan connectors.
Fan Connector Descriptions
Connector Function
System fan (fan 1) Provides +12 V DC for a system or chassis fan. The fan voltage can be switched on or off, depending on the power management state of the computer. A tachometer feedback connection is also provided.
Processor fan (fan 2) Provides +12 V DC for a processor fan or active fan heatsink. The fan voltage can be switched on or off, depending on the power management state of the computer. Check your BIOS, make sure it is not turned off:-)
Both connectors are the same.
Pin Signal Name
1 Ground
2 +12 V
3 FAN1_TACH
To test for proper voltage connect the negative probe of your multimeter to pin 1 and the positive to pin two. It should read 12V. The locations for Pin 1 on the connectors is shown on the 2nd image.
As for your diagnostic LED, you did not tell us which one is lit up. See the attached image for the codes.
Hope this helps, good luck.
Voltage for ATX power supply
Voltage Rail Tolerance Minimum Voltage Maximum Voltage
+3.3VDC ± 5% +3.135 VDC +3.465 VDC
+5VDC ± 5% +4.750 VDC +5.250 VDC
+5VSB ± 5% +4.750 VDC +5.250 VDC
-5VDC (if used) ± 10% -4.500 VDC -5.500 VDC
+12VDC ± 5% +11.400 VDC +12.600 VDC
-12VDC ± 10% -10.800 VDC - 13.200 VDC
このアンサーは役に立ちましたか?
スコア 2
24 件のコメント:
Thanks for your suggestion. But how do I check the connector when it is plug in and turned on? Where do I put the prods?
Regards.
さんによる
disconnect your fan temporarily. Your fan has either 2 or three "prongs" place the probes on the outside contacts. Make sure that you meter is set to V DC and at a low scale like like 30-50V. that way you can see what the voltage is.
さんによる
You mean to place the probes on the fan connector on the board, right?
さんによる
That is correct. Make sure you do not let those touch each other while measuring the voltage.
さんによる
I'm sort of new to this. Could you tell me which color probe to use on the connector?
さんによる
19件以上のコメントを表示
コメントを追加
Definitely sounds like the power supply. If you ever notice weird problems like cd-roms that intermittently work, or hard drives that spin up and down, blue screens etc... always suspect that the psu has gone bad, or partially bad. Easiest way to find out check the voltage readings at the molex connectors, or if you happen to have one handy swap in another power supply and see if the problems stop.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,887
