メインコンテンツにスキップ
The Motorola Droid RAZR Maxx is a version of the Droid Razr carrying a higher capacity 3,300mAH battery.
20回答 すべてを表示
end of head phone jack broke off in phone
was listening to music via head phones, into the headphone port.
when i went to pull the headphones out of the port, the end broke off and i am unable to reach it. if i take the phone apart, will i be able to get to this broken part and pull it out?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 18
20 件のコメント
This worked!!!!!!!!!!
さんによる
This didn't work, nothing against you, it just pushed it in a LOT more
さんによる
Help me this didn't work what do I do now
さんによる
Thanks it worked. I put the super glue on the interior bit of the broken jack (wiped clean the outer bit), pushed it inside, waited for an hour to dry and then yanked it out with fingers crossed. The whole thing came out as one.
さんによる
I tried the glue method and it did not work for me, now it seems that the piece is glued into my ear jack. Any recommendations please!!
さんによる
15件以上のコメントを表示
コメントを追加
21件の回答
ベストアンサー
Take a BIC pen ink tube, insert the tube to the headphone jack and plug the broken tip to the tube and just pull it out, it worked just fine for me, hope you can find this useful.
このアンサーは役に立ちましたか?
スコア 25
28 件のコメント:
Just tried this on my S7 and it worked like a charm thanks for the advice
さんによる
This is an awesome idea. My fiance broke one off in his charge port and we've tried everything we could think of, we will be trying this later!
さんによる
This Works!!
さんによる
The BIC Pen instructions worked, GREAT! Merry Christmas,
さんによる
Easy peasy. Worked perfectly.
さんによる
23件以上のコメントを表示
コメントを追加
this is what i do and it works very well.
try to put a small amount of superglue on the broken end and stick it back in your phone. hold it and let it dry then try to pull it out.
if that doesnt work then take a paperclip straighten the end of it. then hold a lighter underneath it till it is red hot. then stick it in your phone jack and it will melt the plastic and bond to the broken headphone piece so you can pull it out. this method works for me very well
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
Can u do it with gorilla glue or is a different kind
さんによる
Thank u really helped got it out
さんによる
Wow!! My daughter broke the headphone jack in my phone and I was sure it was ruined. I tried the superglue trick and I couldn't believe it worked!! When I first put a dab of glue on the main headphone piece and put it in the phone, I left it in for about 25 seconds and when I pulled it out, it was not fixed, and the glue made it seem as if it wasn't going to come out at all. I put the jack back in, twisted it a bit, pushed in and everything came out in one piece. Absolutely thrilled!! Thank you so much to The PIcklefish!!
さんによる
Thank you so much! Been trying to get a piece of plastic out of my earphone jack all day. Then I heated a safety pin, inserted it into the plastic, waited and pulled it out! So simple! Thank you for sharing!
さんによる
Bad thing i don't have paper clip and lighter
さんによる
コメントを追加
I was listening to music and I set my phone in my pocket and I must of moved wrong and the jack of ear phones got suck in my phone so I took a pin cartridge and put it in the hole then I pulled a piece of it out but there was still some in there so I took some small nettle nose plires and in a sideways motion I took the pliers and pulled it out so basically I dug it out but be careful it could mess up your phone
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
That’s unlucky
さんによる
コメントを追加
Ifixit makes a tool for just this problem...
GripStick Headphone Plug Extraction Tool
GripStick is a tool designed to easily remove broken 3.5mm headphone plugs from jacksの画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Well, is it worth buying if the piece has been pushed in as far as it probably possibly go after trying every other method?
さんによる
Yes, the GripStick would be specially helpful in that situation.
さんによる
コメントを追加
Take a cheap BIC pen and take the ink cartridge out. Then put a small amount of hot glue into the end opposite of where the writing part of the pen is. Quickly insert into the the jack and press for 10 to 15 seconds. Now pull the cartridge out.
It worked for me
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You can use any glue hold it down on the thing you trying to get out for 5 minutes and it comes right out but u can only pull as fast and risk it or go as slow as you can and nothing so have fun wish u the best The end
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I used the glue didnt come iut now really stuck! Any ideas?
さんによる
i dont want glue in my phone but if it works it works, but idk if it works so someone tell me ok.
さんによる
コメントを追加
I got the center part of a pen which was too small to do the first method then melted the plastic with a lighterand stuck it in. I waited a while then pulled it out and it worked! So happy.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I think the best way is to use a needle,birthday badgeetc stab it into the rubber part then yank it out it worked for my apple earphones.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I've put my apple headphones it to my iPhone se and I pulled it out and it snapped I've tried all the ways above any other suggestions ?
さんによる
My grandma could’ve thought of that
さんによる
コメントを追加
All of these above are very good but most are for if you can risk damaging the headphones port. I have a broken off end of my headphone stuck in my £700 laptop. I really don't want to ruin the audio port so is there any safe and easy way to remove it
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Most of these above are good but are they because most of them involve glue and if the glue sticks to the audio port it could be stuck in forever and for my problem I can't risk ruining my device. The end of my headphone broken off in my £700 laptop and I don't want to try a way with glue to get it out so I need the safest and easiest way to remove it.
さんによる
コメントを追加
画像の内容を見る:
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Wonderful getting to know everyone hi I’m Marcus Rashford and I play for Manchester United
さんによる
I’m a billionaire
さんによる
so am I dude.
さんによる
コメントを追加
I’m loving my life living in a mansion playing for Manchester United it’s my dream I’ve also got a Lamborghini Adventador
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
nobody cares'
さんによる
Forget to switch accounts?
さんによる
did i ask
and also idk y i wrote this i am just tired so reading this was sad
さんによる
コメントを追加
Just use the end of a pen tube and force it into the end of the broken headphones. If it’s too big then bite the end of the tube push it in again and pull it out really fast. This worked for me. Hope this helped!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Tried the glue method and it's worse. I am trying the bic pen and now it seems too tight and impossible to remove. Any ideas?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Use a nail cutter (a big one if necessary) and position it to the end/tip of the nail cutter, pierce into the stuck earphone jack and yank it out! Hope this works!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I'm having this situation right now. I managed to get the brass cover off with a safety pin, but the broken piece is still stuck. Any ideas or am I screwed? I just got this laptop at Christmas as a gift
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Get a GripStick from here:
http://nightek.com or iFixit
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How do you get a pen ink tube from a BIC pen like how do you open the pen
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
oof that is sad but u r lucky because i still cant find a pen, poop.
さんによる
コメントを追加
I broke my jack into a point where a normal method is useless, its not at the end. Its the midpoint, so the pen thing is too small. I need help so any suggestions.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
At CareProdx, we offer best in industry ADA door opener, bariatric & wheelchair supplies, handicap equipment and much more. Visit our handicap supply store now!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Umm question, why can’t we solve all our problems by going to a place where they do it for you, and you don’t screw up your phone/laptop. I mean ya it cost money but what if you mess up you laptop or phone when your doing these hacks then what, I’ll tell you 700 dollars down the toilet.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I am unable to remove jack of broken handfree from my mobile .It's LG LS620 and Jack is stuck till far end of phone.I have tried all i could but nothing works
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
コメントを追加
回答を追加する
Charlotte さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 17
過去 30 日: 42
今までの合計 124,739
