メインコンテンツにスキップ
iMac はAppleのディスプレイ一体型デスクトップコンピューターのモデルラインです。
8384回答 すべてを表示
Cleaning the Mac's innards when you are replacing the HD
Plan to exchange original HD for 2TB one. When at it, noticed quite some dust in/on fans and other places. Once read (do not remember where) that it is unwise to vacuumclean the innards. Why?
I have ESD-safe brushes and other gear, will mechanically block the fans (so they cannot act as windmill generator) and use the VC on its lowest powersetting and will maintain at least a 10 cm or 4 inch distance between hose-intake and innards. Still unwise?
Greetings from continental Europe.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Vacuums in-fact create a static charge! The air sucked in at the nozzle creates a mini Van de Graaff generator within the air stream between the different air pressures. - As Machead stated use Can'ed Air to blow the dust and junk away. Scrubbing with a soft artist brush (being careful not to snag any parts with the brush) to help loosen the dust is also a good idea.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Parts can be knocked, torn, or sucked off the board with careless use of a vacuum, that's why blowing is recommended. With your attention to care you should suffer no ill effects.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
OK and thanks for your thoughts and comments Dan and machead3.
F.H.
さんによる
コメントを追加
回答を追加する
Feike Hoogenbos さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 1,084
