メインコンテンツにスキップ
An audio/video receiver (AVR or home audio receiver) is a consumer electronics component used in home theaters that convert signals into sound.
280回答 すべてを表示
Anyone know where I can find a bridge rectifier for Denon DRA-335R?
My bridge rectifier has shorted out, and I need a new one. I can't find one that matches exactly to the one that shorted. Any help would be appreciated. Even if you can't find the part, information as to what the 20 and 11 mean would be nice as well.
Here's the part:
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
fryarludwig , this is a S4VB 200 Volt 4 Amp General Purpose Rectifier that has been discontinued by Shindengen and once stock has been depleted, it will no longer be available. Get the datasheet for the S4vb from here. Check with places like Mouser.com or Digikey.com for an equivalent. I get something like Digikeys PBPC603DI-ND. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thank you for accepting my answer. Best of luck to you.
さんによる
Good answer oldturkey03, Julio Mora
さんによる
thank you JCM :)
さんによる
コメントを追加
回答を追加する
fryarludwig さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 915
